am I just seeing things, or is there some sort of separation or damage in the sleeve at the transfers?
that is the first time Ive seen the intake built onto the cylinder in a ski motor,who ever built it was copying a older style reedless kawi motox engine.they were setup just like that with the long boost port and openings in the bottom aux transfers
How well did that fuel injection system work?
wow that is some porting work. 11mm storker with a stock bore is there a reason to stay with the stock 81mm bore was that a rule in the rule book back then or something? Wouldnt this thing shake pretty bad?
Because an 81mm piston is a lot lighter than a tuna can 86, 87, 88, etc piston. More than one way to skin a cat.
Scottie
The lighter the piston the quicker the engine revs ie: response or as the unknowing think of it, bottom end. Responce and tourque are two different things. When you get into the 87mm+ piston diameter the weight of the piston goes up significantly. Its a give and take thing, heavier piston/more displacement vs. engine rev. acceleration. Waterhawk, I think your right.
What's the advantage of a light piston if your piston speed goes through the roof on account of the increased stroke? Pick your poison I suppose??
I guess that what the long boost port and also two small lower ports are for to get rid of some of that heat. Do you think this is an aftermarket sleeve from back in the day or did he do all the port work and window cutting by hand?
They used to make reed induction cylinder kits for the old 550s back in the day.
The only reason they did this was because the 61x intake sucks. Another thing racers used to do back in the day was actually cut off the intake of a 61x and weld onto it an intake from a 750 Kawi. Pretty much what the 62t cases were designed from.
When they were set up right, they hit very good. Gary Lamb used to use them on all of his skis and he built a bunch of National and World Title winning skis over the years.
Scottie
