skithis
X
- Belleville/ Coldwater, MI
I always see surf vids where guys just come haulin azz up the beach and slide to a stop on the sand. Doesn't this destroy your intake grate and prop?
i do it at least once a ride, only gone through one impeller, it wears out the outside of the impeller running in all the sand. ive refinished the bottom once too, it was getting thin!
SJBrit does it different, he comes wide open to the shore, then cranks the bars into a 90 degree slide and slides up the shore sideways.
Yes it does. And if you hit that big rock, it also makes a huge hole in the hull and throws you over the bars and makes it a lot more difficult to tow your ass back to the marina.
Beached my skis 50,000,000 times, besides loss of gelcoat and a few shell gouges... no problems. Its the pulling it back to the water after beaching, that kills you...lol
You can also lean the ski to the side some as you hit the beach.
Might want to alternate sides, dont want to grind down just one side of the chines!
be careful though, i watched someone almost break their neck flyin over the ski. shutting down at the right time is critical
