- Atlanta, GA
ok so, I go to flush my 08 sxr from a day in the gulf. After about two - three minutes i turn the water off and walk back to the ski to turn in off when out of no where it revs up on its own. I pulled the key out and it continued to run, At this point I panic and pull the plugs, nothing. (now this has happen before when i have had a little gas left and never lasted more in a few seconds, but i had about a half a tank this time.) It ran for about 40 ish seconds and then slowly shut off. Honestly i thought it was going to blow up.
My questions are:
Why did this happened?
How did it happened?
Why after pulling the plugs did it continued to run?
How to shut the ski if it happens again?
And how to prevent it from happening again?
The spark plug look like trash now and I'm going to replace them is there any other thing i should look at before taking it back out?
Also any other tip or advice would be great.
Thanks
My questions are:
Thanks
