1lb ABC fire extinguisher on ebay for $20.
OCD Solutions
Rentz, GA
What sparked this thread was a buddy this weekend who has an extinguisher smaller than a beer bottle. With Daytona coming up I know lots of guys are looking for cheap and simple solutions to being legal.
ger87410
How did I get here?
Fort Worth
aslong as it hasnt been altered and is charged i would think it is ok but every cop has a different opinion on whats legal
They could be super anal, like our lake's patrols.
PORTABLE FIRE EXTINGUISHERS
APPROVAL CATEGORY: 162.028
APPROVAL GUIDANCE & INFORMATION: The Coast Guard does not conduct approval review of Portable Fire Extinguishers. The regulations require that extinguishers are tested, and listed and labeled by a Coast Guard recognized Independent Testing Laboratory. The Listing includes testing, and follow-up inspections by the recognized Independent Testing Laboratory at the manufacturer’s production facilities. Currently, Underwriters Laboratories, Inc. (UL) and Underwriters Laboratories of Canada (ULC) are Recognized Independent Laboratories. Essentially, the recognized Independent Testing Laboratories administer the Coast Guard’s extinguisher approval program on the Coast Guard’s behalf with Coast Guard oversight.
The USCG marking requirements for marine extinguishers differs from NFPA/UL markings. The USCG rates extinguishers primarily on net agent weight rather than on fire test size as determined by ANSI/UL711. Extinguishers with agent weights below those referenced in the vessels regulations and which do not have a minimum 5-B:C fire test rating per ANSI/UL711 are considered too small for marine use and are not approvable.
The Coast Guard does not issue certificates of approval for portable fire extinguishers. Instead, an approved extinguisher are can be identified by the marine type label, such as “Marine Type, USCG approved, Type X. Size X, USCG approval number 162.028/XX.” The XX signifies the laboratory’s identification number for the particular extinguisher. USCG approved extinguishers are listed in the laboratory’s equipment directories and web sites.
The extinguishers are tested for compliance with the applicable ANSI/UL standards. Specifically, extinguishers are expected to comply with the following:
* Foam extinguishers (ANSI/UL8)*
* Carbon dioxide extinguishers (ANSI/UL154)
* Dry chemical extinguishers (ANSI/UL299)
* Water extinguishers, stored pressure (ANSI/UL626) *
* Halocarbon clean agent extinguishers (ANSI/UL2129)
* Fire tests (ANSI/UL711)
* The Coast Guard currently requires additional corrosion tests for unpainted stainless steel extinguisher shells because of prior corrosion problems such shells experienced in a marine environment. This has limited the number of approved water and foam extinguishers.
The maintenance of extinguishers must be in accordance with NFPA#10, as stated on each extinguisher label.
SUBMITTAL PACKAGE: Application should be made directly to the Accepted Independent Testing Laboratory.
DAG
Charlotte, NC
dang, someone snagged the ebay one.
any others in the 1lb range,, i really need to get one thats lightweight.
Waternut
Customizing addict
Macon, GA
One thing to be cautious of... There are plenty of states that not only specify the class of fire extinguisher required but also the minimum capacity required. GA regulations states a minimum of 2 lbs for dry chemical, 4 lbs for carbon. and 1.25 gallons for foam. Thankfully they don't care on my lake.
Waternut
Customizing addict
Macon, GA
Someone try it out and let me know how it holds up in a saltwater environment.
Is there a weight limit for fire extinguishers on a jet-ski?
At least in GA they throw PWC's into the category with everything else that's 16' and under and has a motor. I think the only difference is PWC's aren't required to carry a throwable device but even that isn't written so they could stick it to you if the guy was a dick.
#ZERO
Beach Bum
Florida - U.S.A.
I just looked up the PWC fire extinguisher requirements and it says they have to be coast guard approved class B-1 type.
The USCG B-1 requirements are 1.25-lbs for foam, 4-lbs for CO2 and 2-lbs for the dry chemical type.
See if you can find a 1.25-lbs foam fire extinguisher that is USCG B-1 approved. :fing02:
DAG
Charlotte, NC
Anyone know the psi differeance in foam vs the 100psi dry chemical?
I'm thinking the lighter foam requirement is in a much bigger bottle aka offseting the .75lb savings... havent done my homework
#ZERO
Beach Bum
Florida - U.S.A.
I've yet to find a 1.25-lbs. USCG approved B-1 foam fire extinguisher, they just don't make them anymore.
I've seen the small aerosol cans with foam inside but they're not USCG approved.
