- orlando
what can i use for a cheap releasing agent . Im going to make a carbon fiber ride plate out of my buddies 550 aftermarket ride plate.
what about grease or vasoline or somthin.
if you are only going to make one and you are not concerned about the finish, you can use packing tape(similar to scotch tape). Next cheapest would be PVA (buy at fiberglass store) the application is easy and finish is ok. if there isnt much detail needed you could try swran wrap. If you lay swran wrap, then your fiberglas, then another layer of swran wrap on top then cover it in foam rubber then a piece of wood. Then clamp it or put weight on it it will be a redneck vacuum bag system. (just watch for wrinkles in the swran wrap because they will show) Grease will not work because the fiberglass will mix with the grease and come out all messed up.
