haggis
its raining again!
- Orkney (northern scotland)
I bought a 140mm mag pump a while back and was led to believe it was a direct fit for a superjet. Well i went to fit it last night and to my surprise it comes about an inch short of the stuffer! So it looks like it has a shaft for a set back pump, trouble is its not a set back pump.
So can i use an oem shaft instead?
How do i remove the shaft from the pump?
Also the shaft for set back pump is mabey a 1/4" longer than stock and the splines are 3/4" shorter than stock, is that the norm? just so i know exactly what ive got.
Cheers
Cheers
