Gas tank vent nipple replacement
Delaware
I cracked a vent/return nipple on my SJ tank taking it out and need to replace. I figured just to drill/tap and add a 1/8 barb x 1/4 NPT fitting but what should I do to reinforce and seal? JB Weld, 1200, 3bond, etc?
Thanks,
SUPERJET-113
GASKETS FOR CHAMP BRAP!
Just drill and screw the fitting in, no need for tapping the plastic. It will stay.
I have done to a few tanks with no problems. I suppose you could pust some superglue, silicone, 3bond,5200 or something on the threads when you screw it in.
Ohio
Just a tiny dab of 5200 on the threads. I sealed a second pulse line from some cases and it is solid after years. I just a tiny dot of 5200 to seal the threads.
skinnyman
YOU CANT RENT MY SKI
Dallas/ToyBox
i used a dirt bike tire valve It has gasket and a flange on the bottom and nut holds it in place.Just dont forget to take the valve stem out
im with sj 113
judt drill little smaller than 1.8 fitting and screw it in
ive done a few that was as well
if your worried it will leak put loctite pst on it
jason
