Is this a good line up to completely reinforce 2 B1s and SJ with mashed in nose.
FG-7725-38 8.5oz twill e cloth 38"X25yds 38" Width $156.25
FG-C04Y 8.7oz eglass tape 4" Width 20 yards $20.00
EPOX-635314 1 gal resin 43oz hard MED $65.00
EPX-P31 pump system for epoxy set of 2 $6.25
AC-BL004 black dye 4oz. $5.60
FL-3M050 3M micro bubbles will do 5QTs $9.75
$262.85 total minus rollers/plastic scrapes and the basics.
What do you guys think. Right/Wrong glass or epoxy combo's
You are using 3:1 ratio Epoxy which is great as it will buy you time for a first time.
Tape is up to you, I did not use it on mine but I still double up the glass layers.
3M glass bubbles are OK, I guess, but remember
you are not going to sand it.
Apply the "peanut butter" and when sticky lay the glass, all at once.
When it cures, it will cure ALL together, bondline and glass as one piece.
I used
West Systems 404 instead. You can use
Cab-O-sil too.
Other than that looks good.....now go and Hack it!
Benny
