has this been posted already.... black and green w/ a silver pole looks good.
http://www.kawasaki.com/Products/Pro...scid=21&id=439
huh?you missed the part about it being 4stroke.
Shut up, Jett.
Holy crap when did the retail price go up so high?
huh?
Serious? it says 2 stroke
Engine Type Two-stroke, two-cylinder with crankcase reed valve induction
Displacement 781 cc
Bore and Stroke 82.0 x 74.0 mm
Compression Ratio 7.2:1
Cooling system Inducted water
Carburetion Twin BN40 Mikuni
Ignition Digital DC-CDI
Lubrication Pre-Mix
Starting Electric
Propulstion System Jet pump, axial-flow, single stage
Maximum Thrust 699 lb.
Overall Length 90.6 in.
Overall Width 28.7 in.
Overall Height 28.9 in.
Curb Weight 396.9 lbs.** Includes all necessary materials and fluids to operate correctly, full tank of fuel (more than 90% of capacity) and tool kit (if supplied)
Fuel Capacity 4.5 gal.
Color Ebony/Lime Green
Warranty 12 months
Good Times™ Protection Plan 12, 24, 36 or 48 months
* Not available in California or New York
Benny
If they kept the old pricing they probably would have started selling more SXR's then SJ's.
Its to bad the skis keep getting more expensive with no improvements.
