- Moline, IL
I am considering switching to total a MSD total loss system on my 98 SJ. Can someone give me pros and cons of doing this? I realize you loose your charging capabilities.
I have a Jetinetics charging flywheel and a MSD enhancer. But that does not matter same thing. I was just thinking of maybe trying out a type 9 pipe again and know they need more initial advance.
I have a MSD TL system that is a couple years old that I'm just setting up on a new stroker motor that I had built. You said "Must use the new digital multi-channel MSD-TL"...Lots of power, You can run more compression for maximum performance with a TL, Must use the new digital multi-channel MSD-TL, then with a new battery expect just to charge overnight after a days worth of riding, some things will need to be done on the setup if using in salt/surf. But overall a very good performance gain.
Did you already max out the 62T system with a TBM charging flywheel and a MSD Enhancer?
And, I am going to be using the ski almost exclusively in salt water. What are the "some things" that I, or anyone else, needs to do on the set up?Lots of power, You can run more compression for maximum performance with a TL, Must use the new digital multi-channel MSD-TL, then with a new battery expect just to charge overnight after a days worth of riding, some things will need to be done on the setup if using in salt/surf. But overall a very good performance gain.
Chuck,
Have you set up any motors with the ATP total loss?
I have to admit I like the looks of the ATP total loss. I like that you can use the oem box.
What's so wrong with the single channel TL systems? All the things I've read from people who went from single to multi channel say they couldn't tell a bit of difference. I've also seen just as many multi channel brains go out as single channel.
No, I haven't used one of Chris's Flame ignitions.
From what I know about them, it should be a great ignition.
sounds like i was spot on. half ass grounds ( dirty grounds ) and msd dont go togetherSee post 17
