Once I started building my 07 SJ this ski became the g/f's ski and I promised I wouldn't mod anything unless it was something she asked for. Luckily she loved to ride my ski and I got full permission to make hers the same as mine.
So this is what she got after it became the g/f's ski;
The TBM flywheel was swapped out with a RAD, (TBM went on my 760,
Limited chamber replaced with a Carbon Mod Chamber then swapped back to Limited,
The Riva intake and plate were swapped for a Worx 201 and stock D-cut,
Skat impellor replaced with a 9/15 Hooker by Impros,
Pole was replaced with an RRP,
Chinpad was upgraded to a Wamiltons,
Riva CDI was replaced with an MSD Enhancer,
Coil and Stator was sent to JSS,
Riva F/A's replaced with Proks w/ Outwears,
OEM 38's sent to JSS for his Taperbore Mod and rejet,
Added Greater Girdled head with 35cc domes for 185psi,
X-metal steering was replaced with Wamiltons setup with UMI Sealed Bearings,
Sharkfab Throttle modified for small hands,
Kawi SXI Throttle cable,
SN Fire extinguisher in the tray,
WW Stubby pump cone,
Deka ETX-9 mini AGM Battery...
Custom Battery tray built to fit small Deka Battery
Blowsion Billet Fuel Cap.
I now have a Fresh Freestyle Ported 760 topend on the shelf that will be going in as soon as the cases come back from Team Scream from getting ported. Once things slow down she's finally going to get footholds and turf too.
