Custom/Hybrid Another great Watercraft Factory build!
GIL
Power In The Hands Of Few
Cullman AL
I used bowling ballz in my hull. It don't work worth a dam.:pancake:
LOLOLOLOLOLOLOLOLOLOLOLOLOLOLOLOLOLOLOLOLOLOLOLOL
I was gonna use my shaved ballz----------------but--------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------I could NOT find Cheryl's purse anywhere. LMAO
the WaTeRhAwK
fryin' up a/m electrics..
okc
2 little valve stems sticking out from the bulk head.!!!!!!!!!!!!!!!!!!!!! :arms:
:sneaky:
yeps. either inner tubes, or some type of thick mil poly vinyl bagging that will fill up the inside of the hull to use instead of foam, to displace the water. with valve stem(s) and a pressure guage at the bulkhead.
waterfreak
I had a vision!
s florida
Here's an update. Hull is done except for the footholds and the hood. Hopefully it will go to paint next week and I'm still not sure which color to go with. It's going to be a new ford color (getting painted at a ford dealership) , just don't know which one.
In the last pic, you can see how much wider the tray is. it is similar to the with of the sxr.
Rickster
Matakana Menace
I like the Ford Cinnamon color...
:woot:
i thought we had discovered that not completely sealing the bondline properly got water out the quickest!
...oh yeah... pingpong ballz!
I see your ping pong balls and raise you coke bottles.
