SUPERJET-113
GASKETS FOR CHAMP BRAP!
- Lake Havasu City, AZ USA
Yup, thats where I've seen them injected before.
Suscribed.
My big question is that you normally have a carbed engine with the carb set up for normal running conditions. How do you compensate for all the increased air when you hit the NOS button? Seems to me that it would need to either be jetted really fat to compensate for the increased air flow (which would make it run like crap when running under no NOS conditions). Or you would need some type of fuel injection system with a computer (like the cars normally have) that measures all the typical operating parameters like air temps, pressures, exhaust temps, pressures, fuel consumption, cylinder pressures, ect... But I have seen PINKS where they had NOS on carbed engines so what do I know really, not much.
another nitrous company to check out is boondocker they have 2 stroke kits that would be very easily used.
Among other things We are working on a bottle bracket solution as well as a Mikuni carburetor specific WOT switch.
Among other things We are working on a bottle bracket solution as well as a Mikuni carburetor specific WOT switch. A handle bar activation switch is just lame. There might be cheaper kits out there, but ours will certainly be the best.
Aaron
Open valve, close hood and go WOT? Sorry but not quite familiar with the set up you are referring to. I would assume there has got to be some kind of "switch" somewhere that releases the Nitro into the carbs once you have open the Valve....right?
Benny
Their kit has issues. The fuel part of their kit work's OK for small shots on 350cc ATV's (different style carbs), but is unacceptable for a 650+cc jet ski.
I am working with Bryan Havins (used to be with Nitrous Express, has had multiple magazine cars, designed the first Radio Control car/truck nitrous system) to develop a kit with us.
Aaron
Winner, winner, chicken dinner. You got that part figured out (but I think I mentioned it on page 2, haha). Just need a pressurized fuel source. Most kits use an electric fuel pump, but that adds hassle and weight. I think I have a better idea.Why don't you install a fogger style plate under each carb, or a fogger style nezzle in each manifold?
Brian
