new hard drive
SuperJETT
none
I'm going to use this for off-site backups---plug it in a USB dock, do a massive backup over a weekend, and take it home so it's off-site.
We had a major fire here at work last week that reinforced having a good disaster recovery plan for me regarding my servers/data. The fire was in a production area and caused the roof to collapse plus burned up every wire in the building.
WD Caviar Black, 1TB, 32MB cache, and heavy as a brick compared to most drives. It's also like completely silent.
oxnard111
Creative RE Purchasing
storage capacity it coming down in price.
less platters are better from what I know so take that into consideration when purchasing a drive.
i saw a deal the other day, two 1TB drives for $110 + shipping. Both were 3 platter designs.
SuperJETT
none
Love how prices keep falling on storage.
Wish my backups here at work were under 1TB. :banghead:
My primary backup media is a 4 drive raid 5 array with 10k rpm SCSI (may be SAS) drives. I think I do around 300Gb/night but am in the process of auditing my backup procedures to make sure I'm catching everything.
SuperJETT
none
Is the 4th for hot-spare?
U using a storage tower, then? Which tower?
Dell 2950 2U server, 2 drives mirrored for boot/os, 4 in raid 5 for storage, no hot standby since it's only used during backups. Most of my other servers running raid 5 have a hot standby drive.
ger87410
How did I get here?
Fort Worth
Oh, wow. I've not seen a RAID-5 with more then 3 drives. Not that I've seen many RAIDs. How many of the drives have to fail before the RAID fails?
Currently we're using a RAID-5 with 3 drives and 1 hot-spare. We've been a little disappointed with our current setup as it only takes 2 drives to fail for the RAID to crash.
The problem is we're using DPT crap. DPT got bought out 10+ years ago. (Shows how old the equipment we're using is.) We even got a DPT hot swappable tower with dual power supplies for redundancy. Sounds cool, but 1 PS went already and they stopped making them 10 years ago. We can't even get bays, so only 4 of the 7 bays are being used.
Too bad the hot-swap towers are so bloody expensive.
SuperJETT
none
I've run 6 drive arrays in raid 5, actually have 2 servers running that right now. 5 are in raid 5 with a hot standby, first one fails, the hot standby spins up and is built up and the array is back to 100%. Second one fails, the array still runs with no loss of data. Lose a third and you're toast.
I've had 2 or 3 drives in those servers die over the years and it worked just perfectly, stick a new drive in and within a few hours it's back to normal.
ger87410
How did I get here?
Fort Worth
That sounds like our setup with 4 drives.
I thought you were stripping across 3 or more drives w/ 1 parity drive. I think you can do that. I'll give that a shot when I get some free time, see how well it works for us.
Glory_Freestyle
Old, but still ridin'!!!
I do about 3.9TB for my full backup and around 650GB for my differentials.
When I stream to tape it takes 7 LTO3's.
Our SAN is all RAID-5, two LUNs are 2TB (8 drives, each) and one is 600GB (3 drives). Two fibre cabinets, one is full (13 active 300GB Fibre Channel drives, 1 hot spare), the other has 9 active, 4 empty, 1 hot spare) Hot-swap cabinets are awesome. Well worth the money.
ger87410
How did I get here?
Fort Worth
Wow!
What brand SCSI stuff you running?
Is your stuff rack mounted, then?
We seriously need to upgrade. We're still using SCSI-3 ULTRAwide. But other then the hardware breaking and you can't get replacements, there is no need for it. Our software is designed to run on a Pentium2. :biggthumpup:
Glory_Freestyle
Wow!
All rack mounted Dell/EMC enclosures with Brocade Fibre switches.
Ohio
Thanks Jett....I did not know that.....I only use drives this large for storage so far. Now I may have to drop a black one in for my OS!
SuperJETT
none
I wouldn't use anything that big for an OS myself. They are good performers in their size class, but a WD Velociraptor will destroy it speed-wise.
SuperJETT
none
Yikes and Wow.
After the fire last week, disaster recovery plan is my focus. I'm redoing quite a bit of how I have things setup, including where different machines are.
