I think I might've ruined my MSD brain over the weekend when I hooked up the battery wires backwards. Everything looked good for the first 15-20 seconds and then smoke started pouring out of the brain. Got fuse? None of the wires were even hot though.
Anyway, afterwards the ski suprisingly ran good for the first 5 minutes or so and then it acted like it was only running on one cylinder but even that was intermittent. Fearing the worst I pulled the brain out today and got a nice burned smelling brown goo that squirted out of a crack in the potting.
I'm hoping that the brain is still good but water got inside and I can dry it out on the stove and seal it up real good. What do you think?
edit: The scratch mark you see is actually from the knife I used to peel the sticker back and the crack is actually under the goo.
