- virginia beach
i just bought a westcoast exhaust with the manifold for my js 550 i was wondering if anyone had a picture on how to run the cooling lines for it thanks for the help
what about the other manifold hole if its dual cooled?
well, if the manifold has fittings for dual cooling, and your ski has single, you can just pull out the front nipple, and put in a brass plug from the hardware store.
OK i just teed off the pump to both cooling ports...
ya but i didn't have a plug so its not really hurting any thing right? the tee just adds a little more pressure
Because tees and fittings in general create restriction ,so what you have just accomplished is further restricting the stock cooling system by running it through a tee and another fitting,not exactly what you were shooting for would be my guess.
