water box compare
SuperJETT
none
Nope, but a similar design might be back on the market soon, but with 2" tube instead of 1.75"
lakeboy183
get out and ride
i just got a tdr and i think im an going to run one of my cooling lines inot the box to quiet it down a bit,,as far as to loud im usually good at not staying in the same areas and most people at my lake would think it is cool, considering my lake is kinda a drinking lake
I was in Havasu and the stunt guy on the first video had a very distinctive off set sound it was much more spicey and high tone edgier than the deep braps of Stoyer or other competetiors...I think you will also have to know if ytou are running front or back exhaust.
Ohio
I have a 760 with a TDR with dual cooling and dual jetworks flow control valves set to 3500rpm. It is a little loud off idle but sounds like Jetts when ripping.
Boris
The Good Old Days
If you want to see how loud the TDR will be without actually spending money on one, there is an easier way.
You will need 6" of 1 1/2" PVC SCH 80 pipe and 2- 1 1/2" couplings.
Glue the couplings on both ends of the PVC pipe and insert it in place of your waterbox.
It's a perfect fit on the square without the need to cut hoses.
That sounds just like a TDR and is only slightly louder.
Vincent_85
Take a Stand
Belgium
do you have a dual cooling line?
is the water going in the waterbox allready warm?
you have a Jetworks flowvalve?
