- Charlotte, NC
since i would get too bored just waiting for winter to pass, i decided to build up my seven diffy some more. my plans are to get it lighter and add some power.
current setup...
300 pounds without gas
pjs pipe
ac pole
umi steering + bars(bent)
wamiltons turf and cyclone footholds
advanced timing
bored nozzle
stubby pump cone
and some other little bolt on stuff
what i will be doin...
hopefully somewhere beween 280 and 300 pounds
milled head (probly like 29cc i know every thousanth of an inch is bout 1 pound so about how many pounds is 29cc?)
straight bar turnplate i will make in my c.a.d. class for free:Banane09:
carb spacer plate that i will also make in my class
a port job
maybe bore it to around 800
lighten flywheel (what can i do to lughten this, see pics)
bilge setup
already started makin my composite, d-cut ride plate
superman tray grab handholds
hood mods (cut out baffle, how do i do that? plug holes on top, open up holes in back, and cut in handholds)
my msd ignition enhancer is on it's way
x2 trim could i use the exterior part of a steering cable with a bicycle type cable inside? also, how do you guys with x2 trim have em set up?
i think after i do all this i should have a pretty nice ski, what do you think
:shooter3:
current setup...
pjs pipe
ac pole
advanced timing
bored nozzle
stubby pump cone
a port job
bilge setup
:shooter3:
