Is this paint or powder coat?
SXR-FOREVER
Finally Flippin
Since my motor is out and taken apart I want to paint it and am thinking about one of these colors (either of the red) but have no idea what they are...
Any ideas?
#ZERO
Beach Bum
Florida - U.S.A.
Yep the cases are painted, head anodized, billet cylinder and the bed plates & front cover are ceramic coated.
Powder coating doesn't last very long when exposed to a salt water because it will start to peel up at the machined surface exposed edges.
Also the candy colors are not very durable because it's a very thin coating over chrome powder coating.
If you want any paint job to last on an engine that's exposed to salt water it needs to have a zinc phosphate two part epoxy primmer for adhesion and corrosion resistance.
how would you know.??? :rant:you ski has never seen water , :rant:salt or fresh!!!
get that thing on the water:rant:
Think I found what I am going to do, its duplicolor "metalcast" looks like the same color. I got a good selfetching primer to go with it so we'll see how it will work.
I did a few parts with that its not very durable ,I highly reccomend using a clear automotive topcoat over it .
Q
QuickMick
get a base coat clear coat. Be sure to use a self etching primer that is for aluminum.
Thats what I did.
Waternut
Customizing addict
Macon, GA
Metalcast only works on shiny surfaces... It is basically a clear tint. If you apply it over a dull finish it'll be a dull tint. If you paint it over chrome it'll look anodized. As for durability, I sprayed a few hand tools with it and they looked good until you scraped them up against anything.
It does look cool though!
Yes that why I said clear it,dull or not it will be shiny when you clear it!:beerchug:
