I thought I´d brief you on how everything went with the 760cc.
Got it on place a couple weeks ago.
Little tricky with the stock exhaust mount, mostly because of the dual cooling water out on the head, and the exhaustbracket mount on the head. (Same cylinder and head as the GP760, look it up and you´ll see what I mean)
Anyway, I finally managed to get it on place and did a testrun with the following setup.
760cc kit
Stock exhaust
Stock 38 carbs and jetting
Msd Enhancer
Skat Trak 13/17
Worxintake
I experienced a much more powefull bottom end power, could due to the impeller and enhancer to. But I tried the same setup before i mounted the 760cc kit to and it was different.
But I strongly recomend an aftermarket exhaust system and head, mainly because of the mounting issues with the exhaustbracket but also beacuse the stock exhaust really suffocates the engine.
So I´m planning to mount an b-pipe, head, singlecarb, flywheel and some other acessories.
