Flash-FX
No Square..No Round..FX-1
- South Jersey Shore
In preparation for the 08 season, a inspection of the pump revealed a reduction nozzle issue... some Broken vanes. Hmmmm???, I had this blaster nozzle laying around for a replacement.
After riding WaveHog's and Special FX's ski's with the adjustable trim setup (which is really cool) it is time to give this a shot on the 144mm. Using a Kawi X2 Trim/steering nozzle arrangement, it amazingly fits perfect on the Yamaha/Blaster max flow Pro-Tec nozzle.
Since the Trim ring sets back the cable attach point about 1", I found a sprinkler riser extension worked out as well as a cable end extension. New heim joint ends eliminate all excess steering slop.
One thing I did notice is that the stock Yamaha 144mm reduction nozzle used 2,1mm shims between the ears and the hull. The Pro-tec Blaster nozzle need 4,1mm shims to do the same job.??
Test report soon...:smokin:
![IMG_0215[2048].jpg IMG_0215[2048].jpg](https://www.x-h2o.com/data/attachments/350/350408-d1fdfe5b8275fa812b00fe0ebd3124a5.jpg)
