Cracked Cylinder
MMor101
Very nice, How much?
Skippack, PA
I noticed it today while I was flushing it water was leaking from the crack. Its a GroupK big bore 61x sleeved cylinder. Can I just get a good used cylinder and press the old sleeves in? What would cause it to crack? I dont have a head mounted pipe.
You can press the old sleeves in, but you need to portmatch them (essentially duplicate GroupKs porting work)
Mouthfulloflake
ISJWTA member #2
NW Arkansas
How come? I am running stock 150psi compression.
:ugh:
you need the girdled head because its already cracked once.
how many cylinders can you sleeve and report to match for the $325 cost of an ADA girdled head?
#ZERO
Beach Bum
Florida - U.S.A.
If it's a big bore 61x you won't be able to install sleeves in another cylinder without machine work.
They need to be bored and counter-bored with the proper interference fit, then ported to match.
Big bore sleeves are a different diameter.
Not possible!
If he has a 780cc engine the piston size would be 85.5mm making the sleeves only 2.25mm thick and the bottom skirts would be completely machined away.
I missed the 85.5mm pistons. Where'd you see that?
