DAG
- Charlotte, NC
which do you use mark?
wouldn't that be alot of force revving it up on a trailer?
maybe I"m confused, but you have to rev it up to achieve the highest rpm right?
I guess I"m not following... In order to get the ski tuned to the max rpm, it has to be running right? and it has to be able to rev in order to achieve highest rpm right?
Whoa...I was confused as well. Makes total sense now.
It just seems way more logical than plug checks.
ya, that makes more sense now! I thought you were tuning the high speed, in which it be full throttle runs..
so your saying adjust the low speed screw for max rpms at idle speeds? I would assume you keep turning them out till the ski starts to loose rpms?
Sounds good and relatively easy.
Now if your more then 2 turns out you need to jet up right?
