SuperjetSteve
Go Big or Go Home
- Macomb michigan
Yea pictures explain it all. POS blew up. Any ideas why?
what size pins does a 750 that came out of a 1995 ZXI.
how reliable is this motor? and what should the stock compression be...
sorry for the O/T
bye bye old kawi junk!
those are all 750 motors btw....dont know if they were big/small pin though
It was probably due for a rebuild and blew a crank bearing. (Especially if that is the original crank). Take it apart and see what is salvagable...(cyllinder?)
You can pick up cases cheap ($100). Get a crank from SBT (stronger than the stock Kawi's), and a top end kit from Wiseco. Then bore the cyllinder, reassemble and your done.
