NEW Dasa racing billet PV cylinders
waterfreak
I had a vision!
s florida
Just got this in today:bigok:. Beautifull CNC work from the guys at Dasa. I believe that these are a great inprovement over the cast ones. The only drawback is that you have to do extensive case widening and epoxing.
SUPERTUNE
Race Gas Rules
Clearwater Fl.
Yes, They are heavy duty heavy! The 90mm big bore were cylinders all done with sleeves was 14 lbs by itself, no studs, no pistons, no anything but the billet cylinder, finished porting and finished 90mm bore ready to run.
#ZERO
Beach Bum
Florida - U.S.A.
I imagine these billet cylinders would hold up a lot better in saltwater then the previous cast versions.
Do these cylinders come in different deck heights for stroker applications?
waterfreak
I had a vision!
s florida
yes they do!:bananajump:they can make any stroke without ever using a spacer plate again:Banane57:
