2008 Blowsion/Jet Ski Unlimted built GoFast Sports SuperJet!
Below is basically the article I wrote for Jet Skier UK on the build of my new boat!
GoFast Freeride
Two of the biggest names in the performance watercraft industry, Blowsion and Jet Ski Unlimited (JSU) teamed up to build my new “GoFast Sports” freeride machine. I have no reservation in saying that this is the very best freeride ski in the world today! It was built and assembled by the best motor builder in the industry, Steve Webster at JSU. All of the hull and paint work was done by John Dady and his crew at Blowsion, the undisputed leader in accessories and water craft composites. The project started out as a showroom new 2008 Yamaha Super Jet, which Erik Knoebel, co-owner of JSU was able to get early in the production run from Yamaha. Steve and the staff at Jet Ski Unlimited in Phoenix, AZ stripped the ski down to the bare hull and shipped it to Sherwood, Oregon, the home of Blowsion to begin it's transformation.
Once at Blowsion, John and his expert composites crew of Andrew Cutlip, G-wally, and Matt Geoffrey’s started the fiberglass work that is required on any top level freeride boat. The engine compartment was laid up with a 17.5 ounce stitch-bonded fiberglass weave, while the very high stress areas got a layer of carbon/Kevlar, which not only looks really trick, but makes the ski incredibly strong. A set of Blowsion Kicker foot holds were installed to keep me connected to the ski, the whole tray was reinforced, and a one way valve was installed to quickly get water out of the engine compartment. Just before the ski went to paint, a new JK hook kit (with a visual exterior Kevlar center section) and set of Tubbie 3's were installed. Note (I struggled to get comfortable on my practice boat even after doing all of the other handling changes, and I asked John to send me a set of tubbies to see what that would do on the new ski. This ski carves great, and goes around bouys really well with the new stock hull design...but it would just not do what I wanted it to do in the surf. The original tubbies don't really fit on the new hull, but Tubbie 3's were perfect, and were as much of an improvement on the new hull as they are on the old one. They help keep the nose up, allow the ski to pivot around the front when turning, and basically made the ski more comfortable and fun for me.) After much sanding and shaping, the final step of the process at Blowsion was the amazing GoFast themed paint job. John's paint combined with the attention to detail on the composite work make the hull a true work of art!
While Blowsion was busy building and painting the hull, Steve at Jet Ski Unlimited was creating one of his bomb proof 760 freeride motors. The JSU 760 freeride cylinder is ported for great snap off the bottom and a very strong mid range. The crank was trued and welded, a Blowsion girdled head was installed, and a set of UMI couplers were used to connect the drive line. On the intake side, the dual 38's were switched out in favor of a single Powerbomb 48 and Blowsion flame arrestor. Exhaust is handled by a factory B pipe. This may seem like a relatively mild motor for a professional level boat, but believe me when I tell you that this set up make more than enough power for any sane (or insane) person in the surf! Plus, if my ski drinks a little too much salt water in some far off corner of the world, I will be able to easily find parts to repair it.
As soon as the final coat of paint was cured, the hull was crated up with all the Blowsion goodies thrown in and shipped back to Jet Ski Unlimited for assembly! Once there, lead technician Chad Cole began a meticulous job of putting the entire project together. Skat-Trak's new 13/17 magnum hub swirl prop was chosen to get the power to the water. With the planned addition next month of the new Spring 08 release Blowsion Supercone for the OEM Yamaha 144mm pump this beast is only going to get scarier in the pump and grunt department! The stock steering cable was swapped out for an 07 model to get a little more throw on the modified steering nozzle. A UMI aluminum pole and UMI sealed bearing steering system were installed along with the Blowsion shortened turn plate, UMI 0 degree bars, Blowsion carbon fiber chin pad, and Blowsion lowered billet handlepole bracket. A Blowsion aluminum battery box keeps the battery securely in place and Blowsion Kenney Keepers were used to keep from breaking motor mounts. To help the boat's handling in the surf, a carbon fiber Blowsion D-Cut ride plate was fitted along with a Jet Dynamics intake grate. Bilge pump, bracket, switch, switch cover, and outlet all came from Blowsion as did the bypass fittings. The final step of the assembly process was the installation of Hydro-Turf mats with the 25mil under pad. The extra thick padding not only makes for a more comfy ride, but also really helps absorb impacts of hard surf aerial landings. JSU takes a lot of pride in their work and it shows in every ski they build from world championship winning race machines, (of which they have built many including South African Dustin Motzouris’ World Champion SXR’s) to the average customer's ski that comes in for a little motor or tuning work. And my ski is certainly no exception! One look at the engine compartment reveals the level of care taken in the build of this ski.
After a bit of a break in and tuning session, it was time to put the ski through it's paces in the environment it was built for, the surf! First off, this is the best handling freeride boat I have ever ridden period. The combination of the new 2008 Yamaha hull design, along with a set of tubbie 3's, a D-Cut plate, and a powerful snappy motor make the ski an absolute blast to surf ride! It turns like it is on rails, and with a squeeze of the throttle the electric snap of the motor will allow the ski to slide very predictably. This makes for the perfect handling setup in the waves. When it came time to jump a little, the motor really began to shine. Power is incredible, and the only way I can describe it is electric. It pulls quickly and cleanly off the bottom, then hits insanely hard in the midrange! Big lofty flips off of sloppy 2-3 foot waves were pulled off with ease, and I rode through a full tank of gas with out the first stumble or bog from the motor. Overall, I could not envision a more perfect package in a surf boat. Power is more than enough and very predicable, handling is amazing, the ski feels rock solid, and that new Skat prop hooks up great even in the foam.
The end result of this build is the ultimate freeride ski, a fun rec boat and a great freestyle ski at a very affordable price. For more information on this or a similar package, please contact Blowsion (503.625.3616) and Jet Ski Unlimited (623.581.1620).
<embed src="http://img372.imageshack.us/slideshow/smilplayer.swf" width="426" height="320" name="smilplayer" id="smilplayer" bgcolor="FFFFFF" menu="false" type="application/x-shockwave-flash" pluginspage="http://www.macromedia.com/go/getflashplayer" flashvars="id=img372/2695/1211782252ytu.smil"/>
<br/><a href="http://imageshack.us/slideshow/index.php">Go to ImageShack® to Create your own Slideshow</a>
cattledog
EH TEAM RACING
toronto canada
hey ross you should make a video of your travels around the world, i am sure it would be very cool, maybe one day their will be jet ski builds on tv and coverage of pro freeriders in competition, they have wakeboarding on tv why not freeriding
Thanks very much guys.
I would love to have anyone come and ride this ski! I think it is a great all round ski, and I'm pretty sure if you ride it you will want one. And that means I am doing my job!
As far as the steering, I am using a reducion nozzle and turn nozzle from the 07SJ. It has been clearenced for extra thow. I'm also using the 07 steering cable. But I've just recently learned that the Gp1200 cable has even more throw and can be made to fit pretty easily and I am going to try that soon.
As far as the prop goes, the ski hooks up great as it is...but Blowison is working on a pump cone that fits over the hub of the pump. It is desigend to inrease preassure in the pump and improve performance. The prop I am running now is made to work with this cone. Hopefully I will have tha by the time I see you guys in August at the Blowsion beach party (9th and 10th).
In the mean time, if anyone wants to try the ski...I'm up for a ride in Oceanside almost any time! Hopefully will be able to make it up to Pismo again some time soon as well.
