Hood straps or latch setups
D Slicker
Durham, dont forget it
Pottstown, PA
OK so after my near death experience. the coast guard had to break my hood straps to save my ski. So I am going to replace them. I have seen some neat setups floating around and am wondering if you guy could post some picks. I was thinking on using a setup like this since I don't want to drill anymore holes in my pole bracket.
Frosty
New York Crew
Western New York
Holy crap! What happened man?
I am using E.J.'s SS ratchet setup... it opens fast and easy if you do it right.... pull up on the ratched release, grab the end (tail) hanging out and give it a yank... it will release very quickly... you can see the tail i am refering to hanging down in front of the front foothold.
D Slicker
Pottstown, PA
Where can I get that?
thegoldenboy
RN Surgery... soon
Toronto
I just installed my NJFL straps. They seem like they will work pretty well. Unless you are in dirty surf I think the ratchet strap is overkill.
Great idea though, and I guess you can't overkill on hood security.
wydopen
onthepipe
Wamiltons bungee hoodstraps all the way...super easy to take on and off and you cannot lose your hood with them on...
DAG
Charlotte, NC
x2 been running his for a good season now and they are like new:cheer:
I like those andrew, any pix from the other attachment point???
I fabbed up something similar for daytona that I thought woudl be temp, but I really like it!
for my F1 build I am most likely going to use a single 2" SS ratchet strap from EJ
isnt he WB800 on here??
you just drill two holes in the bracket and through bolt them with the supplied hardware...
nice...the ones I used are adjustable bungee's.....you adjust a hook on either side, and the hook just happens to be a perfect fit to the pole bolt....
the ones I used though are the bungee with all the little fibers..I like how yours is the solid rubber strap....
does it leave black rubber marks on the paint at all?
Nor Cal
E.J. has photos of his brapstraps in his album, im sure someone has photos they can post
Patent pending as we speek. Great system.
you guys think that a single 2" ratchet strap (EJ's) woud be overkill?
looks like the handle is pretty freakin' large..but I do like that nice fat strap....
if going this direction I think I'd use this 2" strap and thats IT
oxnard111
Creative RE Purchasing
though I don't ride as crazy as some... my single 1 inch strap has never failed me yet. There was once on a side landed re entry attempt where it kinda popped a little side ways, but that was my fault for not tightening enough before going out. it was still kinda loose from trailering it. I try not to keep the ratchet super tight unless I'm riding in fear of ruining the hood seal.
