- Cleveland Ohio
I would love to feel how your ski rides. I like what you're doing. You are doing so many things that i've always been too lazy to do. when you're done with yours i 'll send mine up to ya!
Mine will be right behind it! :wall:
Also with how the cable is connected to the trim nozzle, as the nozzle gets pushed up from hard landings it will just slide up the cable instead of binding and breaking the cable with the trim lever not pulled (what was happening with my blowsion/skattrak cable)
Did you run that threw your stock bildge line out thhe back? i had mine run that was but it was hard to move it up into my bracket
same thing happen to me. i drilled a small hole through a bolt, ran the cable through the holes and then tighten it down to the nozzle using a nut and it worked very well and is easy to get on it off.
Very nice. I think you hit the nail on the head with that one. Now I finally understand why my cable is breaking.
