750 Bottom End Same As 800 Sxr ?
sj995
SJ 995
Tn
MY ? IS i'M WANTING TO BUILD A BACK UP MOTOR FOR MY SXR800 i FOUND A BLOWN 750SX CHEAP WANTING TO BUILD IT BACK TO AN 800 THESE ARE FIRST kAWI'S iVE WORKED ON THEY LOOK THE SAME BUT i FIGURE SOME OF YOU WOULD NO IF THERE IS A ERFORMANCE DIFFERENCE.& ARE THE CYLINDERS DIFFERENT CAN i RESLEEVE THE 750 WITH 800 SLEEVES OR CAN i JUST BORE IT .
227
Its all about the surf!
Oceanside, CA
An 800 SXR bottom end is slightly different than a 750 bottom end, however a 800SXR cylinder will bolt up directly to a 750sx bottom end. I wouldn’t recommend doing this if you using a 750 bottom end with a small pin crank (750SX). If you have a 750SXI bottom end with big pin crank it will work fine. I put a 2003 SXR800 on my 1995 SXI bottom end and rode it for 2 years with no problems.
sj995
SJ 995
Tn
sxr bottom end
that's what i needed to know so basically all i'll have to get is an 800 cylinder make shure ive got a big pin crank with 750 cases
I don't see any reason why you can't run an 800 cylinder on a small pin crank as long as you use the small pin pistons. 82 mm bore piston are available. That will make it the same bore as the 800. A plus is the crank is lighter.
yeah thats what im runing at the moment . ported small pin cases and crank, 82mm wisco pistons r&d head .
im about to build another engine with the same set up but this time im going to use 85mm pistons in it
