Best way to tow two Superjets behind a boat?
cambo au
TRYING TO LEARN
AUSTRALIA
after all this i would say boris has the right idea you wont tow a superjet with no one on it with out it subbing as far as the water ingestion do what hangtime said or just ball valve the cooling inlet lines you
i like borriss idea but i would say join all of the bunks together at the rear so it cant slide side to side and cover the under side with plywood ar strong plastic so that it planes on that you would be good to go
vitaly
Анархия - мать порядка!
NY/NJ
Get a cheap zodiac inflatable and put your skis on it side by side, tow the zodiac.
BTW, zodiacs are fun too. This way you have four great toys: the boat, two skis and the zodiac.
Jetaddict
9 years to retirement...
Tampa Bay
You're not going to be able to throw those skis on that stern deck. Unless you have some serious help, and are going to be in shallow water when you lift them, it's gonna be a bit**. You possibly could fit them up there-one on the sun platform and one on the stern, but you had better make sure they are tied down GOOD, otherwise you are gonna fu** up your boat bad if one of them takes a tumble. I'd say go with the tow rig or the flat boat idea other people are suggesting. You have to weigh the headache/fun factor too. No one wants to be fiddling with something all weekend to get it to work right for just a couple minutes out on the water.
I've used them clips you can get from the dollar store that are suppose to seal up your open chip bags. I bealive they are refered to as the 'CHiP Clip' use'd that to pinch the water line in from the pump to the motor. worked sweet.
not a chance in hell that will work
you could do it with a set of vice grips, but a chip clip? :twak:
motoman25...that boat looks real familiar,we run the same hull. What kinda speeds you gettin outa the 115 hp with 2 superjets on board
WaveDemon
Not Dead - Notable Member
Hell, Florida
thats pretty funny
hangtime
Speak up ,don't kiss azz
The OEM water line is pretty soft and flexible but I doubt it would work .
Not only that but I wouldnt trust a 2 dollar piece of plastic to protect my thousnads of dollars worth of motor
Shonuff
I've got the glow
Memphis
Not sure if this will hold 600# being towed but here's a gentler approach. It's frickin' huge at over six feet long.
$125
