W
wydopen
ive been running no bildges with no problems..dont let that keep you out of the water..if you sink it at least you will get some practice getting it fired again..:fing02:
you have stock still?ive been running no bildges with no problems..dont let that keep you out of the water..if you sink it at least you will get some practice getting it fired again..:fing02:
some more less important stuff
25mm Hydro turf underpadding...
UDI locking grips
straight bars
shortend turnplate
handpole limiting rope
and one day you'll wish you had one... guaranteed
if not how is that possible??
straight bars
that's great if you don't run a pump.
But it's terrible advise
why..if it gets wet it gets wet..bildges dont do anything...just more garbage in the engine compartment..im not saying dont run em im just saying you can go out for a surfride without a bildge..
Cause one day your not gonna be able to hold your ski out when the engine compartment is completly full and that bilge would be pumping water out, making it semi manageable to drag it back to shore.
I have about two or three stories bad moments would have been worse if I didn't have an electric bilge.
I
Yamaha elec boxes are not the most waterproof of items. Carbs and fuel with water in them suck. The battery leads with fried ends suck. And green wires suck too.
that doesnt make any sense, if i had no bilge pump my ski would be full of water in a half hour. whenever my ski is upside-down or on its side it takes on water, without any way to get it out wtf u gonna do?no bildges whatsoever..when i had em in my old ski i never turned em on..then they broke and i never fixed em..i wish i had filled the hole where the bildge was on my new ski...now i just have the through hull fitting elec taped
wait u DO have a oneway though right??
