gunrgood
Almost ready
- Macramento
has anyone installed blowsions one way dump kit? how is the product?
			When the foam gets wet it will drip dry between rides. ...
can someone post a pic of the one ways from home depot.
i have the blowion valve and am very happy with it!
and i will buy another for my next build
i will never do another scupper!
did you get the hole kit or did you just buy the valve? what does the kit come with, if you bought the kit?
Each pre-assembled kit includes explicitly detailed instructions (the time saving coring tool hints are worth the kit price alone), two Blowsion molded glueable urethane bulkhead and ski flanges for leakless sealing, recessed one way flow valve, special flex tubing ( allows for off center mounting unlike straight PVC tube scupper systems ) mounting epoxy and stainless fasteners.
why the one way valve, unless it will be floating for some time, if not just get a scupper valve from x-metal or wam and cut a hole in the rear and one in the front, cut out the foam and you are done. When the foam gets wet it will drip dry between rides. I'm running two and have no problems, although I must keep an eye on the ski and run my bilges when needed, heck it makes it more exciting...
I have a blowsion 1 way in my fx-1...
this is the DRIEST ski I have ever owned....!
