Pulse line problems on rn superjet
McDog
Other Administrator
Staff member
South Florida
I just replaced all the fuel lines on my 96 superjet with ebay lines. I even replaced the pulse lines with it, which I'm afraid was a mistake. The fuel just pulses back and forth about a 1/2 inch in the supply line and nothing is coming out the return line. It won't freaking start!:banghead:
The ski ran fine before. I tried priming the lines and it didn't help.:banghead::banghead:
Have I screwed up by replacing the pulse lines with fuel line?
HELP ME PLEASE!!!!!!:hail:
DAG
Charlotte, NC
make sure vacuum line i not getting pinched/sucked shut
it alsways takes a few times to get it going once its all relined.
BTW: ling to the hose you bought? i gust got some neon line and it worked just fine,,, so far
#ZERO
Beach Bum
Florida - U.S.A.
I made the same mistake using Motion Pro Tygon fuel line for a pulse line hose and found it to flex too much.
It also leaked around the short brass primmer fitting because the line seemed bigger then the stock line inside diameter.
Make sure that your brass pulse line nipple didn't come lose from the case.
#ZERO
Beach Bum
Florida - U.S.A.
I purchased all new oem fuel line from boats.net and put everything back to stock.
My ski ran with the aftermarket pulse lines but I was losing some signal to the fuel pumps with the soft, thin, larger diameter tygon line.
McDog
Other Administrator
Staff member
South Florida
Yes I am using the fuel valve...I'll check on that tomorrow. I'm pretty sure it's all hooked up right though.
Thank you Mr. Vomit.
McDog
Other Administrator
Staff member
South Florida
I also just replaced the flywheel and bendix but didn't touch the stator. Could it be a problem with timing?
McDog
Other Administrator
Staff member
South Florida
I guess it has to be the fuel lines. Hopefully I switched up the fuel selector valve lines but I gues it could still be the pulse lines collapsing.
McDog
Other Administrator
Staff member
South Florida
I sort of tried that. I used a syringe to put fuel in the supply line....still wouldn't start. How would I dribble gas down the carb?
that will tell you that you dont need to pull off your flywheel
that will tell you to look @ your fuel system
to me it sounds like you have a fuel line swaped somewhere
the main line in goes to the bottom fuel fitting on the carb
Shrivel
Requires therapy.
Acworth, GA
It may also get enough fuel running through the system that all the air is blown out and your suction is normal again. Another option is trying to start the ski with both carb throats covered with your hand. This will create as much vacuum as possible to force the fuel running.
McDog
Other Administrator
Staff member
South Florida
I had the supply line and pulse line switched up! It started first try after that!
:hail::hail::hail::hail:Everyone who posted with ideas
Now everyone forget that I ever did this:sneaky:
