Best power plant for a freestyle 750sx?
227
Its all about the surf!
Oceanside, CA
Yes, An SXR 800 cylinder will bolt directly to your 750 bottom end AND you can use your 750 crank and 750 head. You don't want to bore your old 750 cylinder out to equal the 800 cc's because it will still have crappy bottom end. Have you ever wondered why a 701 superjet has way more bottom end hit than a kawi 750? It's because the kawi 750's port timing is set up for top end for racing, while Yamaha engineered the super jet for bottom end torque. Kawi changed the port timing on the SXR 800's to have much better bottom end hit. The only problem you MAY have is that the Kawi 750SX has a small pin crank which will wear out quicker than the big pin cranks that the 750SXI and SXR 800's have.
FreestyleFreak
Region 7 AM Freestyle
sxr motor
If its gonna were out cranks then i should just get a sxr motor did go right into ot to save all the time on cranks.Will the sxr motor bolt rigth up with no mod?
Prem1x
Tinkering obsessed
Austin, TX
If you're not pulling high RPM's constantly, I wouldn't worry about getting a big pin crank.
Do some search for those Japanese X-2s and see what crazy cylinders they are putting in those.
FreestyleFreak
power plant
I talked to the best kawa mechanic RD.He said with a pipe and prop it will help alot with bottom end.So i think i will save up and go with that for now.
sjetrider
That is where to start bro. After that the big pin bottom and small pin top and an enhancer will be next fo sho. :biggthumpup: OR sell it now and put NO $$$$ in it and save for the often imotaded but never duplicated :hail:SJ
FreestyleFreak
starter
The pipe and all that will have to wait awhile.My starter or starter soiliniod went bad.:banghead::banghead::banghead::banghead::banghead::banghead::banghead:
So..how do i figure out which one it is?
