RiverRat
- Louisville, Ky
what size tube does a x-metal scupper use?
I still think scuppers help sink boats.
Turn it upside down and a scupper becomes an air vent,
allowing the trapped air to escape and the boat to swamp.
I thought about it and decided not to install one.
But, then again, I dont ride surf!
Then you need to change the rubber or its not installed correctly. If I let mine sit in the water, it sometimes leaks a tablespoon every minute. Most of the time the water tension keeps it sealed pretty good.They are terrible. I leaks as if you have a hose inside your hood. 2 bilge pumps hardly keep up with it.
However, I have a mod I'm working on that should eliminate the float-n-leak. I'll post more after a few tests.
Nope. It uses the big mouth type scuppers and will retro-fit on any of these XMW or Wamiltons versions (essentially the same)Would by any chance that mod be called a one way valve ?
btw they use thin wall pvc hard to find 2" i had to go to a landscape desighn place to get it. i tried 4 homedepots and 2 lowes. i think its called 100psi its for sprinklers.
