you wont get the volume... run 2
just drilll 2 holes ..its only one more than one
thats a fairyrific idea, i might just do that :arms:Just drill two. Make it spit out the opposite side, that way when you look at your ski from the side you still only see one.
You can run one pump through the stock bilge but they're a few reasons not too. The stock hose is 3/8" and your bilge probably 3/4" hose. Also you have to use the stock siphon hose or you will sink the ski. The stock plastic elbow siphon break fitting has a real small pin hole, so if the pump is under pressure it will squirt a small amount of water inside your ski.well i dont have a stock bilge on the ski, so what about running one bilge to the side and one into the pump like the stock bilge?
