Midshaft Talk - Building, Rebuilding, SN vs. RN, etc.
FRANCE
Only comes out between the 2 rear seals when you use the grease fitting.
When the shaft is out, you can grease everywhere by hand.
Precisely this is what I'm doing, when I use the grease fitting nothing comes out. It comes out there received_3815795658485501.jpeg
It can be obstructed ? Or the 2 rear seals are mounted too tight.
JetManiac
Stoked
orlando
How far is the rearmost seal pressed in? If it is pressed in too far, then yes it will be blocking the grease hole inside.
FRANCE
The rearmost seal is pressed 2mm.
I have an old midshaft housing and a rod get in IMG_20210226_224353.jpg in my new midshaft housing impossible to push in IMG_20210227_215137.jpg
Midshaft press-through is critical because this helps to determine the amount of spline overlap. The factory specified amount is 19.5-20.5mm as measured between the rear of the housing (not the rear of the seal) and the rear of the shaft.
When completing a build it is important to check spline overlap, especially with a/m hulls, custom builds, and setback pumps with a/m shafts.
Degrease both driveshaft and midshaft splines first. Install and align pump. Then put a small amount of grease only at beginning of the driveshaft splines and then install midshaft. Carefully remove midshaft and check how far the grease was pushed. Sometimes you need to repeat several times but this is the only way I know to accurately check spline overlap.
If you need to press shaft farther in to correct for a spline underlap, you can add an additional washer behind midshaft coupler to maintain alignment.
Got a few questions on a recent midshaft issue
The shaft removed from a 1990 superjet (100% original) doesn’t match shaft pushed out of 1998 Superjet. Nor is the 19.5mm achievable as shown by jet maniac. The shaft bottoms out long before 19.5mm sticks out. 1/4”++
#1. Did the 98 I got the shaft from have an aftermarket shaft that’s not to spec?
#2. Are they really different?
#3. Can someone measure a true known OEM 94-20 shaft
I find that the splines are about 6-7mm, at least, farther up or forward in the 94-20 shaft than the 00-03. Not technically enough drive shaft engagement
so I’m really hoping my 98 shaft must of been a typical junk aftermarket than oem.
however coupler mounting edge to end is identical on both so I’m guessing it’s intended for a superjet 94-20 regardless of oem or Aftermarket. It just isnt really the same size between models (wouldn’t surprise me) or a piss poor job of copying
see pic
JetManiac
Stoked
orlando
see pic
The shaft on the right in your pic is definately not a 98 SJ RN shaft. The RN midshaft shaft has a shelf on it where the coupler washer rests that is larger in diameter than the shaft itself.
JetManiac
Stoked
orlando
see pic
This is a new OEM SJ midshaft for comparison. Your 98 shaft should look like this.
See the lip I was talking about
JetManiac
Stoked
orlando
The rebuild kits have a couple O-rings in them - where do the O-rings go? Can you run without them?
Inside the rear of the midshaft shaft itself. There are 2 grooves where they go. They seal water from getting to the splines and washing out the grease.
Mike75
Billy Racing
Michigan
Didn’t see any mention about how far the front seal needs to be pressed into the midshaft housing. Is it critical? I have mine almost touching the steel keeper
Anybody ever see the engine side seal pop out?
My son's SN that has been great for years came out yesterday. His is an older one without the grease fitting so the only grease it has has is Maxima Waterproof when I rebuilt it.
JetManiac
Stoked
orlando
Yes, quite a few times. Heat from out of alignment or a failing bearing can cause a seal pop. Sometimes there is no obvious reason.
Have you checked to see if the bearing is failing and causing it to overheat?
The grease fitting only puts grease between the 2 rear seals. The idea is to replace the grease that gets washed out over time. as the shaft moves off axis the grease is sucked out over time. So even with a grease fitting, it doesnt grease the front seal or cause a front seal to pop.
We glue the front and rear seals after install on our pro seal upgrade builds to help prevent seal pops in front or rear and to keep rear seal aligned. On a brand new oem housing with a new oem rear seal, the fit is fairly loose and you can adjust the seal alignment by hand. So we worry about it shifting in use.
Also seals out corrosion from that area.
I installed new bearings and seals a few years ago but low hours when we swapped his 650 for a 701.
Never been regreased. Alignment look to be good.
Maybe I will try and clean it and pop it back in. What do you suggest for "glue"?
JetManiac
Stoked
orlando
Clean the area well and any glue like super glue or epoxy, etc.
Thanks JM this really helped me out this weekend.
I had to get creative
