I've been rebuilding my 2001 Yamaha XL 800 and after rebuilding one carb I attempted to check the pop-off pressure, but have discovered that air leaks out where body 2(the piece with the check valves) and the main body meet. It occurs at around 60 psi (pop-off should be about 80)but I was wondering if it leaks because there is no fuel, or if something needs to be corrected. I removed and cleaned the surfaces and made sure there was no debris creating a leak.
