bored&stroked
Urban redneck
- AZ
I was recently diaging a problem with a ski and my buddy pointed out the rubber gasket in the pump area was wrong [#5 on the chart]. I had used the large hole gasket instead of the small hole which is used on 44's. I had never know about the differences, so I pulled apart the set of 38's on my wave raider to confirm I had the right, large opening [5a] gasket according to the rebuild chart. Turns out I did, but it looks the same as it did on the 44's [with the exposed O ring], like I should be using the small hole gasket. So what gives?
