- Asheville, NC
I got cabin fever and cut my rails… I probably should have done this when I built my rails up initially, but I don’t think it really matters that much. The rails will be thicker than they would have, but I don’t mind. I thought about this for a long time and decided that the wide rails around the nose would try to plow through a wake or wave VS moving the rail up, and allowing the rocker of the ski to lift the front end. I am going to cut slits in the rail vertically to allow it to follow the rocker of the hull itself. Maybe I’m crazy but it had to be done! Does anyone have a suggestion on how close the cuts should be together to allow the rails to flex up properly? I was thinking each 2” or so…
