You make it sound easy, ill try it. Thanks1/2 impact the flywheel bolt will come right out. then use any puller.
It is easy.You make it sound easy, ill try it. Thanks
Flylock is nice for torquing flywheel bolt when reinstalling them also.It is easy.Now getting the coupler off the back is a pain in the arse without the right tool..
Yes, wanted it for rebuild as well.
