- Metro Detroit
I just have to decide if I want to make a baffle or run it wide opened inside just like the superfreak box that I based this on. Then make sure the halves are clocked for optimal hose alignment and glue the halves together.Not so much,if it will blow,but when.I can appreciate the effort but after seeing aluminum units split wide open, I can’t help but wonder how much structural integrity is required to make a unit that will stand up.?.?.?
why even bother to make or use that? you might as well just put a piece of hose or tubing in there , since that unit does basically nothingI now know why everyone who has made a waterbox like this says that you couldn't make and sell them profitably. But it came together ok. View attachment 372942View attachment 372943View attachment 372944View attachment 372945View attachment 372946I just have to decide if I want to make a baffle or run it wide opened inside just like the superfreak box that I based this on. Then make sure the halves are clocked for optimal hose alignment and glue the halves together.
so this wasn't today but this is a super mega duty drop hitch for the Ez-Ski Duramax . will be adding stabilizer bars with heim joints at a later dateView attachment 390269
That just takes you to a website.You may look into these (https://www.4wheelparts.com/p/pro-comp-shock-mount-conversion-kits/9495) if you want a bolt on option. They are pretty beefy.
Sean
