schicks
Karma Enforcer
- West Michigan
I had these around for a while, trying to decide if i should save them or scrap...
Lower case half has bearing chatter grooves where the inner bearings rides. Not real bad. Little bearing retainer and go ride? All the bearing lock pins are good and the upper case half is fine. Its just a cheap 701, not an expensive motor.
