Port it yourself and you can save a ton (or ruin several good parts)
When I first ported my cylinder it was so worn out that I had to change spark plugs every ride, BUT . . . BUT it hit like an SOB when it ran. I fried several sets of pistons, but had a ton of extra stock pistons and just kept changing them out until I had to bore it out.
T cases - ported by me $150
kawi reeds $20 ebay
Kawi reed stuffer $20 ebay
chuckies spacer $80
x cylinder - ported by me as per an old ric roy cylinder (plus 2mm) $100
b pipe - ported by me (46mm) $200 (back in the day, before they were premium)
44s with drilled out return (and other funkiness) $100 (yes you can find them cheap)
stock intake -$20
stock flywheel $?
cdi - modified in house - $20
Dremel $40
Bits $75
ADA Head with 34.5 cc domes - $200
$875?
I love to cut stuff up, and hate to spend $$ and time waiting for others to do it. I've always had more than one set of cases and cylinders so I wasn't afraid to mess it up. I asked a ton of questions and took notes.
This has been pleanty of power until now. However, I've got an 5mm lamey flattop stroker that I've got $2500 in the top end alone that I plan to drop in after March . . . so . . .
