Superjet hull wieight??
I would agree, since my never seen the water hull started at over 110lbs...:rolleyes:
Take out the foam and you are around 95lbs:biggthumpup:
Note: If you dont put foam back in your boat make sure to reinforce tray area "inside". I did only one layer of Kevlar, and it wasnt enough. I had a fracture I repaired in the right rear upper corner from doing roles at Daytona...... the fracture didnt go all the way through......it wont happen in that spot again........ it also could have happened from someones boat slamming into mine on the beach too? Not sure.
Rickster
Matakana Menace
Foam is definitely going back in...:biggthumpup:
