Mike W
Infidel
- North Florida
I tried to search for an old thread that talked about the same kind of damage I just ran into but I just can't find it or anything like it.
Anyway, after a quick looks see behind the flywheel cover on my X2 before I put the tank back in I found an absolute mess. So I tried removing the flywheel in order to clean everything up but the flywheel was stuck and wouldn't come off. So I removed the motor and I was finally able to get the flywheel off. In the process of removing it with my puller it looked like the woodruff key was jammed which kept it from coming off. As you can see in the pictures the flywheel and crankshaft started sharing metals at some point in the past so now I need to find out how to fix the crankshaft? The flywheel is a goner so I will be looking for a replacement. Any suggestions?
