- Rexburg, ID
So with my old pump I could flip my ski. Mind you the pump shoe was literally falling out and sucking air off idle bad.
Now my new 155 with 11/15 ish prop new trim also and I cut my plate flush with the hull. I land on my head every time. It Jumps out of the water and feels like it has more thrust which it should!
Couple things might be going on here.
Prop to steep can't turn it fast enough down low.
Thrust pro trim has less tilt than my thrust original. Maybe it's just not tilting enough?
Cutting my plate flush might not have enough surface area on the bottom and it's just blowing through the wave.
Normal riding around I didn't notice any change with the ride plate.
Any pro tips?
Sent from my SAMSUNG-SM-G890A using Tapatalk
Any pro tips?
