- Home of the Steelers!
So... ordered a Solas 148 mag pump and wear ring from www.impellers.com and when it showed up the box was damaged and one of the brass cooling fittings was busted. Two interesting observations...
Look how thin the brass is on the barbed portion of the fitting (no wonder it broke).
The threaded part of the brass fitting appears to be straight machine thread as opposed to tapered NPT thread usually found in aluminum stator sections.
I'm gonna have to see where I can find a brass 3/8" barbed 90 fitting with machine threads :-/
So here's an updated pic. I went downstairs and grabbed a 90 brass fitting which goes to the bottom of my TNT exhaust manifold. It ABSOLUTELY is NPT. It's hard to tell from the pic and I'll add another pic so you can see how far each threads into the pump.
