So basically over the winter I took my superjet apart to get it painted and on the assembly I upgraded the following things
-h20 waterbox
- msd ignition
- 9/15 hooker impeller
- blowsion steering cable
- jet maniac throttle cable
- replaced all dual cooling lines & gas lines
- added a flow restrict or
- got my bpipe power coated & replaced all gaskets and new coupler
last year without all the upgrades it ran strong this year starts great sounds good just doesn't seem to have any bottom end power I don't know if I need to do anything cause I changed the waterbox. I have both dual cooling lines going into bpipe manifold. Then bottom of bpipe chamber to head other side of head right out pisser . Top of bpipe head tees into flow restrict then into chamber on one side other side right out pisser. The pisser from the head the water felt only warm not hot. I just noticed that one of the dual cooling lines at the pump was only half on.any help would be great thanks.
-h20 waterbox
- msd ignition
