Just4Fun
First World Problems...
- Southern Oregon
I have a Yamaha Sj style driveshaft that is slightly bent from removing a prop. Has anyone ever had any luck straightening one of these or do you just hang them on the wall of shame?
With out a pretty heavy lathe and some accurate indicators I don't think I would try and reuse it.
1/2" is a lot! Slightly bent to me would be like .010"!If you spin it like 1/2" of oscillation.
Use more heat next time you remove an impeller dude! I cant even imagine how you bent it removing the impeller.
cut the end off and make a spline tool out of it
Heat is why my driveshaft bent I had a 6' cheater on it wouldn't budge. Oxy/act rose bud for like 30 seconds and bent the shaft because I didn't have the housing clamped properly.. I didn't build the pump the first time.
I used grease when I reassembled with my new shaft, just took the impellar back off with a open end wrench no cheater bar..
